Want to remove shower-room mirror. 15 Sep 2024 19:29 #1
  • johdia
  • johdias Avatar Autor
Hi All,
We have recently purchased a 2023 Globecar 640 Summit Prime which we really like. However, when rinsing after shaving there is simply not enough space between the front edge of the oval basin and the mirror to hold my head over the basin, so the floor gets wet.
The only solutions I can see are:
(1) swap the basin for a much larger (round) one. This looks like a very awkward and potentially risky task.
(2) remove the mirror and mount one in a better position. This is my preferred option.
I’ve taken out the several screws that seem to secure it to the swing shower door it but it’s still held fast. I reluctant to use force.
Has anyone removed this mirror? Or alternatively can offer a different solution?
Take care John
Want to remove shower-room mirror. 15 Sep 2024 20:34 #2
  • Starfish_1
  • Starfish_1s Avatar
  • Dank erhalten: 277
solution #3: Shaving with electro razor. So do Ii. 😉
lg Uwe
Summit 600+, Citroen Jumper 140 PS, Baujahr 2021, 175 Ah Creabest LiFePo4, PV mit 210 kWp Schindelmodule, 500 W Wechselrichter, Thule Omnistor 6300, Truma CP Plus, Gas Duo Control, Regenrinne, Linnepe Zuatzluftfeder 8 Zoll, Thitronik Sicherungssystem
Want to remove shower-room mirror. 15 Sep 2024 21:35 #3
  • Youngtimer
  • Youngtimers Avatar
  • Dank erhalten: 1917
Hi John,
the mirror is glued so it will be a risky task to remove it. Anyway, another guy just replaced the basin which looks really great now. Perhaps it might be the easier way after reading his thread here: poesslforum.de/forum/poessl-h-line/19428...mmit-prime-eingebaut
See you
Lars
Lars
Summit 640 Ducato 5/2018
Folgende Benutzer bedankten sich: johdia
Want to remove shower-room mirror. 18 Sep 2024 17:58 #4
  • johdia
Thank you to all who replied to my "mirror" post.
I've looked at the post by the chap who replaced the bowl but it's a little too involved for me. So, I'll either have to live with it or devise a different solution.
John :)
